| | #2 (permalink) | |
| Senior Member Join Date: May 2009 Location: Kent
| Re: cg125 big end bearing Quote:
Buy Haynes manual. Buy gasket set. Engine out. Split crankcase. Fit new big-end bearing. Rebuild crankcase fitting new gaskets. Refit engine in frame. Swear lots when it won't start. Swear lots more when you find the fault hasn't been cured after all. ![]() Out of interest, why do you think it needs a new big-end bearing?
__________________ Bogof xx )) There's only ONE f'in Bogof (( >>Tagline Made in China - Beware of Falling Let...<< ==> If everything had a point, Chavs wouldn't exist <== --> Too Much Effort, Too Little Reward <-- ~~Stop being so nosey!~~ ters | |
| Member Join Date: Feb 2010
firstly thanks a lot mate for replying long story short, got haynes manual got a complete gasket set allready rebuilt engine still got it apart rebored and honed i know its the big end bearing because there is so much play in it you could move it from lands end to john o grots and when i spray with wd40 shards of metal come out which suggests roller bearings have fragmented |
| | #4 (permalink) | |
Or am I misunderstanding the problem?
| Senior Member Join Date: Nov 2008 Location: Newbury Berks
Sounds like the engine is so fucked I'd just buy a new one if I were you.
__________________ The views/opinions expressed in this post are my own and do not reflect the views of The Biker Forum, its management, and/or owners. Should you find yourself offended please immediately un-read the above post. If you choose to continue reading you do so at your own risk and Ollyc and Co. do not accept liability for any economic loss, damage to property or death and personal injury arising from the reading of above post. |
| Thread Tools | |
| Display Modes | |
