Old 06-09-2008, 04:20 PM   #11 (permalink)
Re: Blackbird battery boiled
The blackbird (and other hondas) is around £70 unless anyone knows different
Spree is offline
Old 06-09-2008, 04:56 PM   #12 (permalink)
£61.32 from wemoto Honda CBR 1100 XX1/XX2/XX3 Blackbird 01-03 Battery Yuasa
give me time and i'll find it for less
..........................Sam
druidsam is online now
Old 06-09-2008, 05:22 PM   #13 (permalink)
BLACKPANTHER's Avatar
Sorry to hear you've had probs, as we both know they're usually bullet proof. The only common probs I've heard of on the 'Bird are because some riders tend to put too much load on the electrics, with heated grips, seats and other gizmos. For the sake of a few quid, I'd just change the recrifier. Never used a Gell battery, but I'm guessing they're expensive. Sounds like ya had a lucky escape on the motorway. Before you set off on the bike again just repeat 3 times "Blackbirds never break down".
BLACKPANTHER is offline
Old 06-09-2008, 06:00 PM   #14 (permalink)
£56.99 here Motorcycle Batteries > HONDA > CBR1100XX
told ya it would get cheaper
.............................Sam
Old 06-09-2008, 07:41 PM   #15 (permalink)
not one of THOSE seats BP
Old 06-11-2008, 03:14 PM   #16 (permalink)
Just checked the voltage out and it's charging at 18.5v at 2000 revs so the regulator looks very suspect. The battery seems fine though as its reading 13.4v with ignition off. I might just try replacing the regulator first to see how it goes.
Spree is offline
Old 06-11-2008, 03:37 PM   #17 (permalink)
deano's Avatar
I'm sure yer completely competent spree, but may be worth a read as ya do it
about: Changing the Honda Reg/Rect
deano is online now
Old 06-11-2008, 04:32 PM   #18 (permalink)
Thanks Deano but thats for using a R1 rectifier as a replacement. The one I ordered is a pattern part that I saw recommended on another forum. It was cheaper than most too.
Heres the link for anyone else. Jaws Motorcycles and Motorcycle parts supplys for the Blackbird
Spree is offline
Old 06-11-2008, 10:16 PM   #19 (permalink)
deano's Avatar
sounds a good find Spree, probably even better than the popular R1 replacement firestorms have the same prob
deano is online now
Old 06-11-2008, 10:27 PM   #20 (permalink)
Yea Deano, theres quite a few Honda's that use the same part. Apparently they seem to last between 15000 and 30000 miles and mines done 21000 .
One thing that I have read in loads of articles is "don't use the Honda replacement"
Spree is offline
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
