| | #21 (permalink) | |
Posts: n/a
| Re: Blackbird battery boiled Quote:
Then check the charging rate again. | |
| | #22 (permalink) |
| Re: Blackbird battery boiled Already did that ![]() |
| | #23 (permalink) |
| Re: Blackbird battery boiled Update..... I received the new rectifier/regulator this morning so off to the garage ![]() It took around 10 mins to replace and another 5 mins to check all the teminals and connections again for tightness. Its looking good now, the charge readings are 14.2v @ tickover and 14.5v @ 5000 rpm. The battery might have escaped damage as it was still reading 13.2v disconnected so I will give it a couple of weeks and check it again. A tip for Blackbird owners, you don't need to remove the seat cowling to replace it as the manual says. if you undo the first and second (luggage hook) bolts then you can prise it away from the frame and keep it open with some scrap cardboard while you undo the two screws with a small 10mm socket. You can then pull the rectifier up through the cowl and disconnect it. Replacement is just a reversal of that procedure. |
| | #26 (permalink) |
| Junior Member Join Date: Jul 2008 Location: bolton
| Re: Blackbird battery boiled spree pop it down and i will test reg and check everything else .jono sometimes you can just plug reg in and go but sometimes wires from alt r split or reg plug melted and couple of rides later same thing happerns better to b safe than pushing it back home :] Last edited by rudiemoto : 07-28-2008 at 11:54 PM. |
| | #27 (permalink) | |
![]() I will pop down though for a brew one day ![]() | |
![]() I read that smoking weed destroys your brain cells - so I gave up reading ![]() Why not try out our other sites? The Biker Cafe and Bikerholic | ||
