Old 08-02-2008, 06:21 AM   #1 (permalink)
dtr 125 2004
my dtr 125 is choking up wont rev at all had new piston, rings ,barrel,power valve opened
rody999_123 is offline
Old 08-02-2008, 06:28 AM   #2 (permalink)
Bill CBF1000's Avatar
Re: dtr 125 2004
Hi and welcome to the forums - would be nice if people could be polite enough to introduce themselves first before just stating whats wrong with their bikes - might even get more responses !
blocked air inlet
blocked air filter
choke stuck on
or ... stupid as it seems and dont laugh cos I once had something similar .....
dirty / knackered spark plug
timing out
incorrect fuel mix if a two stroke
lots of other things
Thufferin' Thuccatash
Bill CBF1000 is offline
Old 08-02-2008, 07:50 AM   #3 (permalink)
Re: dtr 125 2004
2 stroke single w/c with powervalve.
err,, 'power valve opened' well there could be your problem if you've just done it?
power valve should only open at higher revs, having it stuck open all the time to get 'full power' doesn't work too well as you will get bogging down at low revs.
also if just rebuilt if it's piston ported is the piston in the right way round?
and is the head/barrel etc torqued down to the correct tightness?
personally i'd reset the powervalve to standard (reconnect it) and try that first.
Old 08-02-2008, 09:23 AM   #4 (permalink)
Re: dtr 125 2004
Has your question been answered rody999_123?
Your next port of call should be the new members section where you can introduce yourself eh!
Old 08-02-2008, 02:01 PM   #5 (permalink)
Re: dtr 125 2004
im a nice person but i dont answer questions from new members whose first post is a begging post
Old 08-02-2008, 04:00 PM   #6 (permalink)
Re: dtr 125 2004
i have a springer called roddie! he's mental
.............................Sam
Old 08-02-2008, 04:40 PM   #7 (permalink)
BLACKPANTHER's Avatar
Re: dtr 125 2004
I'm not so nice. My advice would be to try putting sugar in the tank. I'm sure ther's a song that goes " A spoonfull of sugar helps the engine go round ." ( I'm joking, DON'T try this Grotbag!! )
Last edited by BLACKPANTHER : 08-02-2008 at 04:47 PM. Reason: There may be someone on this forum even less knowledgeable than me? who may actually have put sugar in their petrol tank!???
BLACKPANTHER is offline
Old 08-02-2008, 06:55 PM   #8 (permalink)
Re: dtr 125 2004
OOoooo
Tut at you BP!! Even I know that sugar goes in the car tank NOT the bike!
