| | #11 (permalink) |
| Member Join Date: May 2008 Location: tyne & wear
| re: How to .... clean and adjust your chain Spot on information and pictures, all i would like to add is that you should find the tightest spot on the chain to do the adjustment, as they dont always wear evenly. Then when you have finished the job spin the wheel and check the tension at several points on the chain. If you have an excessivley tight spot it can shag gearbox/wheel bearing, or even snap |
| | #15 (permalink) |
| Senior Member Join Date: Aug 2008 Location: Gorseinon, Swansea
| re: How to .... clean and adjust your chain Pardon me for jumping in (to the conversation) Just got my second bike after passing my DAS and want to look after it as easily as possible. Just had new chain and sprockets fitted when it had its MOT and would like to look after them without too much trouble. The cost of the scottoiler kit is only marginally more than the chain kit. |
| | #16 (permalink) |
| re: How to .... clean and adjust your chain ah right! Should have thought about it longer ......... but still wouldn't have got it! ![]() One of our members also does one, Drive Chain Oiler |
| | #19 (permalink) |
| Re: How to .... clean and adjust your chain My chain needs ajusting every other day, and i have not got the correct tool to loosen the wheel nut. Why i am eating my chain so quickly, i have not even exceeded 55mph on it (because of wear in)? I am lubing it everyday, i have TURUNO too. I am doing around 60-70miles a day on it though. Can someone help me out here? i am baffled...????? |
