Old 08-13-2008, 11:27 PM   #11 (permalink)
Re: 50cc moped
so how do i test the spark plug , hold the plug with some pliers or something with a rubber handle , pop the ht lead onto the end of the spark plug , and then get some one to kick it over ?
will a spark still be created if the battery is flat?
xr2irhys is offline
Old 08-14-2008, 06:43 PM   #12 (permalink)
Re: 50cc moped
? bump
xr2irhys is offline
Old 08-14-2008, 06:54 PM   #13 (permalink)
Re: 50cc moped
a google search for ' how to test a spark plug' brought up these xr2irhys
how to test a spark plug - Google Search
Old 08-15-2008, 12:57 PM   #14 (permalink)
Re: 50cc moped
thought that was the way , thanks anyawy
xr2irhys is offline
Old 08-15-2008, 04:16 PM   #15 (permalink)
Re: 50cc moped
erm' when you kick the bike over with no plug in, do you get any petrol/smell of petrol from the cylinder/plug hole??
Old 08-17-2008, 06:34 PM   #16 (permalink)
Re: 50cc moped
had another look today , swapped the carb over to my other one which i knew works fine , so thats now not a worry that its the carb, how ever it doenst seem to be getting fuel now , no fuel in the filter at all , does the fuel pump need power in the battery for it to work , or will this opperate on the kick too?
may be this is my problem and its not getting fuel now
xr2irhys is offline
Old 08-17-2008, 06:38 PM   #17 (permalink)
Re: 50cc moped
As i said before I not familiar with your model... but is it not gravity fed.. in the main fuel pumps on bikes are reserved for fuel injection models...try the fuel on "prime" setting
Old 08-17-2008, 07:31 PM   #18 (permalink)
Re: 50cc moped
hello mate what do i need to set to prime ? how is this done useally?
yes its gavity fed and got the pipe with pressure being applied from the engine , can feel it creating presure
xr2irhys is offline
Old 08-17-2008, 08:09 PM   #19 (permalink)
Re: 50cc moped
That sounds like the vacuum hose.. does it come from between the carb and before the engine??
It connects to the fuel tap and the pressure you feel opens a valve in the tap to let the petrol through.
To set to prime turn the petrol tap to the prime position. That will bypass the vacuum hose tho you will need to shove a bolt in the end of it to blank it off while you tinker.
Old 08-17-2008, 08:32 PM   #20 (permalink)
Re: 50cc moped
hi mate the vacumme hose comes from off the engine , which is then connected to the fuel pump , unless i have followed the pipes wrong while refitting new engine , as thought the vaccume pipe would supply the presure from the bottom of the fuel pump , which would then pump it upwards into the pipes?
xr2irhys is offline
