Old 08-12-2008, 04:56 PM   #1 (permalink)
50cc moped
i have a honda bali sj50 moped.
just fitted a new engine in and it wont start .
just fitted all panels back on and tried kick start and electric start still wont start
there is fuel going in and a spark
all electrics are connected up and that no loose wires/cables
does anyone know what it cud be ? or what we cud try?
much appreciated
hello just bit more about the bike its a 2 stroke and its air cooled , by fuel going through , there is fuel in the fuel filter , just a question , with the battery being flat , will the fuel pump be able to pump fuel round to the engine to allow the engine to run ? as i know the battery is flat as the electric start is slow and sluggish and sounds like like a car would , with a flat battery.
the person i brought it from claims it was running when it came out of the bike.
i know it has compression , but only know this by the sound of it , could it loose compression while being transported around and re-fitted into a new moped ?
ignition timing , do 50cc mopeds have ignition timing , i never knew they did , how does this work ?
xr2irhys is offline
Old 08-12-2008, 05:13 PM   #2 (permalink)
Re: 50cc moped
You might have fuel to the fuel filter, but it might not be getting to carb.. If it has been stood or whatever then the carb will prolly need priming. Also the carb may have acquired some crap and it may benefit from a clean.
As for the timing, yes there is a cdi unit which will control the ignition timing.. engine has to get a spark at just the right time..
have you done a compression test?? if not I would give it a go.. I guess you would be looking for 130-140 psi ish (but that is only a guess)
Old 08-12-2008, 05:18 PM   #3 (permalink)
Re: 50cc moped
hello no i have not done a compression test as i do not has the compression tester to do so , the CDi unit works fine as old engine ran on that cdi okay too.
how would i go about cleaning the carb , there is a plastic cover in the way of the bolts to remove the carb , which i do not know how to get off , and i dont really want to take it off as will have to then replace the gasket on the carb too.
xr2irhys is offline
Old 08-12-2008, 05:59 PM   #4 (permalink)
Re: 50cc moped
if you can see bottom of carb, there is probably a drain screw, loosen this and any dirt/water will be able to drain out.
Old 08-12-2008, 10:15 PM   #5 (permalink)
Re: 50cc moped
Lot of questions there eh xr2irhys.
I think you may find that more members will chip in with some advice if you let them know you've just joined the community we have here.
Have a look in this forum New Members - The Biker Forum
and post a brief introduction on a new thread please.
Old 08-13-2008, 05:54 AM   #6 (permalink)
Re: 50cc moped
I am not familiar with the specific model rhys sorry, but you would prolly get away with removing the carbs and reusing the gasket if you are careful not to tear it... handy temporary gaskets can be made out of weetabix boxes and the like
Have to checked you are getting a spark?? remove the plug, and earth it out on the engine. spin the bike over.. is there a spark??
Old 08-13-2008, 12:19 PM   #7 (permalink)
Re: 50cc moped
i dont like weetabix boxes so i use frosties boxes, cause they smell better
Old 08-13-2008, 01:20 PM   #8 (permalink)
davethemonkey's Avatar
Re: 50cc moped
and there was i using silly old gasket paper! cocoa pops from now on!!!
davethemonkey is offline
Old 08-13-2008, 02:13 PM   #9 (permalink)
Re: 50cc moped
hello ive removed the HT lead and sparked that on the bolts on the frame etc , cannot see a spark but can hear it clicking , and feel it , as got a shock lol.
have not tried sparking the spark plug against any thing though
xr2irhys is offline
Old 08-13-2008, 06:13 PM   #10 (permalink)
Re: 50cc moped
I wouldcheck it with a plug in coz although ther might be enough umph to give u a wollop, it might not be enough to get a strong spark
