| Garage - water in the engine? As you know my honda cg 125 seized up because it burnt oil, then had no oil. The garage i have taken it to says that there is "water in the engine". Is this possible? If yes, how? Rob |
| Senior Member Join Date: Jun 2008 Location: Altrincham, Cheshire
| Re: Garage - water in the engine? Usually it can be caused by condensation my brothers Z1000 was like that when you looked at the oil window the oil was milky looking once it had been warmed up and run round for a bit it would disappear only to there the next day. Considering the CG125 is a a aircooled bike its the only thing i can think of |
| Re: Garage - water in the engine? What explanation did the mechanics at the garage give you Rob? |
| | #5 (permalink) | |
| Re: Garage - water in the engine? Quote:
if i were you i would take someone with you who knows about engines (car or bike don't matter) to see them and get a proper explanation of whats wrong. | |
i've got corner speed, it's control i struggle with! | ||
| | #7 (permalink) | |
| Senior Member Join Date: Oct 2007 Location: Leigh Lancs
also there was an oil years ago that was notorious for this ![]() | |
Thufferin' Thuccatash | ||
| | #8 (permalink) | |
Could this have done it? Rob | |
