| HOW TO:- perform an oil and filter change Based on Suzuki Bandit 600 For this you will need... TOOLS Paddock stand (if bike does not have centre stand) Bowl Socket set with appropriate socket for drain plug Filter wrench A tub in which to place bolts etc MATERIALS Oil of correct grade and type Appropriate oil filter for bike ![]() 1) Warm the engine of the motorcycle. Warm oil will run out of the engine more easily, and this should ensure less old oil is left behind to contaminate your nice clean oil. However this means your exhaust pipes will be HOT. BE CAREFUL 2) Support the motorcycle in a level position Again this is to ensure all the oil runs out of the engine ![]() As you can see the bucket has already been positioned to catch the oil when the drain plug is removed. 3) Remove the filler cap ![]() And store this safely ![]() 4) Remove the drain plug Before doing this first check around the plug for an oil leak.. Then using a socket and wrench remove the plug. ![]() ![]() 5) Inspect and clean the drain plug There is a magnet in the top of your drain plug which holds bits of metal which have been floating around in your engine. Generally the cleaner the plug the better the overall health of your engine, although there is little you can do if it is very furry. Clean the swarf off the magnet. If you noticed before removing the drain plug there was an oil leak from the drain plug then replace the washer (with the correct drain plug washer, not a general washer) 6) Allow the oil to run out the engine.. It will take some time for the flow to stop completely. 7) Remove the oil filter This should be done with use of a proper filter wrench.. However if one is not available (say you lent it to someone and not had it back yet ) then you can take the more extreme violence approach we adopted..which is to hammer a screwdriver through the old filter and use that as a lever to twist off filter..![]() 8) Fit new oil filter Get your new filter, using a finger rub clean oil onto the rubber seal around edge of filter. The new filter screws into place, to hand tight only. DO NOT OVER TIGHTEN FILTER. 9) Refit drain plug. Again take care not to over tighten this bolt. Specific figures for the torque of this bolt will be in your handbook. Make sure you do this before pouring oil into the bike as the oil will go all over the floor ![]() ![]() Oh well it was only half a litre before we noticed my deliberate mistake.. I was flushing the motor honest guv ![]() 10) Pour in the appropriate amount of the correct grade oil It is as important to ensure you do not over fill with oil, as under fill. The correct grade and type of oil will be specified in your hand book. Remember to allow for the fact your filter will need charging.. In the case of the Bandit 3.5l of 10w40 does the trick. Refit filler cap. 11) Finally start your engine Be gentle with the throttle, do not rev the engine.. She will sound like a washing machine full of spanners for the first few seconds, and expect the oil light to stay on for longer than normal. All should return to normal in 10 seconds or so but I like to leave her run for around a minute on tick over just to make sure all is ok. Repeat process as per service schedule Last edited by jonnywombat : 08-17-2008 at 05:11 PM. |
| Senior Member Join Date: Jan 2008 Location: Doncaster
| Re: HOW TO:- perform an oil and filter change 9) Refit drain plug. 9) Refit drain plug 9) Refit drain plug 9) Refit drain plug Not that I've ever forgotten, mind. Ive found the oil drains a little faster if the bike's on it's sidestand, assuming the drain plug's on the same side as the stand. I think it is on every bike. Haynes recommend using the centrestand, but I just pop it on the centrestand after draining. Last edited by BLACKPANTHER : 08-17-2008 at 09:45 AM. |
| Re: HOW TO:- perform an oil and filter change Thanks for that jonny & Phil, I could follow that. Is it just newer bikes that have a magnet on the drain plug or do older bikes have em too? |
| | #9 (permalink) | |
| Re: HOW TO:- perform an oil and filter change Quote:
