| Junior Member Join Date: Aug 2008 Location: Cornwall
| Oil Advice & Recommendations Here! I get asked many questions about oil so I thought a thread here for all oil related questions would be a good idea and build into a FAQ or reference point for others. So, put your oil questions here but please give the following information if you would like a recommendation: Make Model Year Engine size/type Any mods Type of use (road/track) Additional info (max oil temps, current oil used) What do you want a recommendation for? Engine, Gearbox etc? I hope this will help and become a useful thread Regards Guy |
| Re: Oil Advice & Recommendations Here! Are you aware one of your vans (well the tanker which goes to houses, probably heating oil) choked me when i followed you along penzance promanade last year? Lol don't worry about it, but it is worse than some of the old double deckers. What oil would be best for the following? Make: Aprilia Model: Rally Year: 2002 Engine size/type: 49.26cc Any mods: Polini Variator, Open air filter, upjet, sports exhaust, 3.5 gram rollers, high compression piston rings. Type of use (road/track): Road but ragged. Current oil: Strawberry semi-synthetic What 2stroke oil and final drive oil would you recommend? Make: Honda Model: CG CDI (Import, 4 down manual) Year: 2000 Engine size/type: 125cc Any mods: Mukuni GP2 Carb, K&N Air Filter. Type of use (road/track): Road, not ragged unless overtaking :P Current oil: Unknown, had the bike about 4-5 weeks. But it is a 4stroke. What engine oil would you recommend? It is burning too much oil. Rob Last edited by robertall : 08-21-2008 at 04:19 PM. |
| Re: Oil Advice & Recommendations Here! make, kawasaki model, zx7r p6 year, 2001 size, 750cc mods, full akaprovic system with tri can, 4 degree ignition advancer, slipper clutch mod, zx7rr flat side carbs, modded cams with 3 angle valve seats and titanium valves and harder springs, balanced con rods and a balanced crank, nearly forgot carbon race spec air box and KN filter to be honest i cant remember what oil i put in last time, so what u think |
