Old 09-19-2008, 02:40 PM   #1 (permalink)
zx6r undertray fitting help!!
just got my undertray in the post looks good, but no instructions but it looks like an awful lot of original plastic needs to be cut away, don't wanna do it till i know i should cos it's kinda no goin back!! any ideas?
Old 09-19-2008, 02:52 PM   #2 (permalink)
Re: zx6r undertray fitting help!!
I fitted a powerbronze one to my firestorm, yep, you have to cut a hell of a lot of undertray to make them fit (or at least I did) but I did gain a load of stashing space.best advice would be to get hold of a 2nd hand undertray from a breakers, even one from a bike thats damaged, or had an undertray fitted before would be worth it.
Old 09-19-2008, 03:46 PM   #3 (permalink)
i know all bikes are different, but my undertray on my zx7r fitted without any cutting, once id removed the complete rear mudguard assembly
Old 09-19-2008, 04:05 PM   #4 (permalink)
mine goes from battery box all the way to rear mudguard in one piece, so taking the whole thing out can't really be done. think i might hang fire until i get a 2nd one as a spare.
Old 09-22-2008, 05:58 PM   #5 (permalink)
Re: zx6r undertray fitting help!! fitted it!
oh yes, that involved some cutting, a bit more cutting and then some cutting.
had to remove rear then front seat,number plate,indicators,grab handles, rear seat lock, battery, rear bodywork/tail piece.
then remove standard mudguard assembly, place undertray on original and cut all excess off, carefully, small amount at a time just in case.
here's some pics.
IMG]http://i331.photobucket.com/albums/l445/skodaphil/zx6r%20undertray/Image052.jpg[/IMG]
there you go, easy (erm don't do it unless your sure,there's no goin back once you cut the original)
Old 09-22-2008, 06:33 PM   #6 (permalink)
Ahhhhhhhhhhhhhh soooooooooooooo that's what an undertray is!
Old 09-22-2008, 06:34 PM   #7 (permalink)
thunderlad's Avatar
Now all ya need Phil is a Tailtidy for ya indicators
LIVE IN 5TH GEAR
thunderlad is offline
Old 09-22-2008, 08:28 PM   #8 (permalink)
will have a nice stainless one tomoro hopefully, will make it in work if there's time
Old 09-23-2008, 11:46 AM   #9 (permalink)
looks good did u get the tail tidy made?
Old 09-23-2008, 04:20 PM   #10 (permalink)
yep here it is (seperate thread how to... to follow)
universal (well i made to the size i needed)stainless steel tail tidy.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43
