The Biker Forum: Changing rear pads - The Biker Forum
Jump to content
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Changing rear pads Removing the pin Rate Topic: -----
Posted 05 March 2017 - 05:25 PM (#1) User is offline   aysgarth boy
  • Litre Club
  • PipPipPipPipPip
  • Group: Members
  • LocationAYSGARTH.NORTH YORKSHIRE
  • I Ride:kawasaki z1000,you ve been tangoed
Help, so ive got the rear caliper off, removed the split pin but the pin that runs right through that you are supposed to take out wont budge, so the question is, does it just pull out or does it unscrew out, its defo not an alan key type if this all makes sense, I'm struggling to get a grip on it now with the long nosed pliers, ive lubricated it up to hell.
life is good
0
Posted 05 March 2017 - 05:59 PM (#2) User is offline   trippo
  • Moderator
  • Group: Moderators
  • LocationCoventry
  • I Ride:Triumph Explorer.......should have done it years ago
Most pad pins either screw out and would have some kind of tool head on it ie Allen key or a slot for a screwdriver head, if not it could be a pin with perhaps a split pin through it at the far end, but it this case there should be movement in the pin for it to be removed.
Hope that helps 😁
Posted Image
Casualty is full of people who thought they knew better!!!!!! Dont become one of them :eek:
Trippo? Why you might ask! I dont fooookin know :D
Strangers are only friends that you have'nt met yet!
I'm completely responsible for my own irresponsible actions :D
0
Posted 05 March 2017 - 09:20 PM (#3) User is offline   b_hawk111
  • Litre Club
  • PipPipPipPipPip
  • Group: Members
  • LocationMilton Keynes
  • I Ride:Bandit 600, VFR800, RF900R
My calipers have got pins and r clips.
My pins just pull out, bit if they are really stuck some have to drill through the caliper to the pin, then you can knock the pin out, only needs to be a 1.5mm drill bit or so, just enough to get something though there to knock it trough!
Posted Image
0
Posted 06 March 2017 - 07:15 AM (#4) User is offline   aysgarth boy
  • Litre Club
  • PipPipPipPipPip
  • Group: Members
Hope that helps 😁
Cheers trippo, its got a split pin but the bloody thing is solid, its not budging and its been well lubed up, think I might just have to take it to the garage.
life is good
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
IPB Skins by Skinbox
Skin and Language
